Ir para o conteúdo principal
HTC Desire 530 Micro USB Port Replacement
O que você precisa
  1. HTC Desire 530 Micro USB Port Replacement, Micro USB Port: passo 1, imagem 1 %32
    • Remove the four 1.2mm screws in each corner.
    • Use the suction cup and plastic opening tool to pry the screen from the body.
  2. HTC Desire 530 Micro USB Port Replacement: passo 2, imagem 1 %32
    • Gently pry the battery up at these three spots, and disconnect the power cables attached.
  3. HTC Desire 530 Micro USB Port Replacement: passo 3, imagem 1 %32
    • You can then fold the battery back like so, and that will give you access to the screw.
  4. HTC Desire 530 Micro USB Port Replacement: passo 4, imagem 1 %32
    • Use the screwdriver to remove the 1.2 mm screw at the bottom of the phone.
  5. HTC Desire 530 Micro USB Port Replacement: passo 5, imagem 1 %32
    • Once the screw and the black plastic backing are removed the daughterboard pulls right out.
  6. HTC Desire 530 Micro USB Port Replacement: passo 6, imagem 1 %32
    • In order to fix the Micro USB Port, the entire daughterboard will need to be replaced because all connections are soldered in.
Conclusão
Uma outra pessoa concluiu este guia.
Eric Blackstock
Membro desde: 10/24/18
403 Reputação
Autoria de 2 guias
Equipe
UMASSD-PEAK-F18S3G2 Membro de UMASSD-PEAK-F18S3G2
Community
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 625
