Ir para o conteúdo principal
HTC Desire 530 Battery Replacement
O que você precisa
  1. HTC Desire 530 Battery Replacement, Battery: passo 1, imagem 1 %32 HTC Desire 530 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Use the plastic opening tools to remove the plastic speaker covers that are attached through an adhesive layer.
    • They may be difficult to peel off and you might want to consider loosening the adhesive layer by running a hair dryer or a heat gun over it briefly to allow them to peel off easily.
  2. HTC Desire 530 Battery Replacement: passo 2, imagem 1 %32 HTC Desire 530 Battery Replacement: passo 2, imagem 2 %32 HTC Desire 530 Battery Replacement: passo 2, imagem 3 %32
    • Use the T5 Torx screwdriver to remove the four screws in each corner.
    • Make sure to take out any SD cards, located on the left side of the phone before proceeding to the next step.
    • Use the plastic opening tool to pry the front of the device off. Fully go around the front with the plastic opening tool before attempting to pull it off.
  3. HTC Desire 530 Battery Replacement: passo 3, imagem 1 %32 HTC Desire 530 Battery Replacement: passo 3, imagem 2 %32 HTC Desire 530 Battery Replacement: passo 3, imagem 3 %32
    • Dislocate the small piece with the wires connected using a nylon spudger.
    • Loosen the adhesive layer for the battery by running a hair dryer over it briefly. After the adhesive is loosened you can pry the battery out with a plastic opening tool.
  4. HTC Desire 530 Battery Replacement: passo 4, imagem 1 %32 HTC Desire 530 Battery Replacement: passo 4, imagem 2 %32
    • After prying, simply lift the battery up and out of the device.
Conclusão
Alyssa
Membro desde: 10/24/18
205 Reputação
Autoria de 1 guia
Equipe
UMASSD-PEAK-F18S3G2 Membro de UMASSD-PEAK-F18S3G2
Community
Membros da 3
Autoria de 10 guias
2 comentários
Mi phone is sealed no scrows on my phone HTC Desire 530 so haw can i get the Battery out
robert jelley - Responder
My phone is sealed so awe can i get the Battery out it is HTC desire 530
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 23
Duração total: 4,202
