Introdução
This guide will show the reader how to remove the motherboard of the HTC amaze by accessing the motherboard through the removal of the back panel of the phone.
O que você precisa
Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
