Ir para o conteúdo principal
HTC 7 Surround Camera Replacement
O que você precisa
  1. HTC 7 Surround Camera Replacement, Back Case: passo 1, imagem 1 %32 HTC 7 Surround Camera Replacement, Back Case: passo 1, imagem 2 %32
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC 7 Surround Camera Replacement: passo 2, imagem 1 %32 HTC 7 Surround Camera Replacement: passo 2, imagem 2 %32 HTC 7 Surround Camera Replacement: passo 2, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC 7 Surround Camera Replacement: passo 3, imagem 1 %32
    • Separate the screen and back cover with the opening tool.
  4. HTC 7 Surround Camera Replacement, Rear Camera: passo 4, imagem 1 %32
    • The camera is attached to the device by a sticky double-sided piece of tape. Insert the plastic opening tool under each side of the camera until it is removed from the tape.
    • The camera lens should then come off after enough force is applied, and room will be made for the replacement to be inserted.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 180
