Introdução
This guide is used when the speakers are damaged or do not produce sound. You will need to use a little bit of force to remove the speakers from the tablet.
O que você precisa
Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
Using tweezers or your fingers, disconnect the two speaker cables by pulling them free of the socket connectors.
Quase terminado!
Conclusão
