Ir para o conteúdo principal
HP-Pavillion 500-424 PC Series CPU Fan Replacement
O que você precisa
  1. HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: passo 1, imagem 1 %32 HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: passo 1, imagem 2 %32
    • Lay the tower down carefully on its right side, with the vents pointing up.
  2. HP-Pavillion 500-424 PC Series CPU Fan Replacement: passo 2, imagem 1 %32 HP-Pavillion 500-424 PC Series CPU Fan Replacement: passo 2, imagem 2 %32 HP-Pavillion 500-424 PC Series CPU Fan Replacement: passo 2, imagem 3 %32
    • Use the flat head #6 screwdriver bit to unscrew the tower casing.
    • Very gently slide the case towards you.
    • Lift the casing up and gently place it off to the side.
  3. HP-Pavillion 500-424 PC Series CPU Fan Replacement: passo 3, imagem 1 %32 HP-Pavillion 500-424 PC Series CPU Fan Replacement: passo 3, imagem 2 %32 HP-Pavillion 500-424 PC Series CPU Fan Replacement: passo 3, imagem 3 %32
    • Unplug the fan from the motherboard by gently grasping the connector and slowing pulling up.
    • Remove each screw from the fan using the Phillips head screwdriver bit.
    • Place the screws in a cup, they are very small and can be lost easily.
    • Remove the old fan from the CPU.
Conclusão
To reassemble your device, follow these instructions in reverse order. Now you should feel confident replacing the CPU fan in your HP desktop without any difficulties.
Amanda Milby
Membro desde: 09/13/18
177 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 43
Duração total: 1,905
