Ir para o conteúdo principal
HP w2216h Power Supply Replacement
O que você precisa
  1. HP w2216h Power Supply Replacement, Screen: passo 1, imagem 1 %32
    • 'Make sure you are grounded, the power supply is not connected and you are wearing safety goggles.
    • Use the Philips #000 screwdriver to remove the 4 round12mm screws on the back panel.
  2. HP w2216h Power Supply Replacement: passo 2, imagem 1 %32 HP w2216h Power Supply Replacement: passo 2, imagem 2 %32
    • Using a Philips #000 head remove 2 flat 12 mm screws above stand mounting bracket.
    • Using a PH1 Philips head with the 150 mm flexible extension remove 1 Philips head screw under the stand mounting bracket.
    • Stand will easily pull off.
  3. HP w2216h Power Supply Replacement: passo 3, imagem 1 %32 HP w2216h Power Supply Replacement: passo 3, imagem 2 %32 HP w2216h Power Supply Replacement: passo 3, imagem 3 %32
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  4. HP w2216h Power Supply Replacement: passo 4, imagem 1 %32 HP w2216h Power Supply Replacement: passo 4, imagem 2 %32 HP w2216h Power Supply Replacement: passo 4, imagem 3 %32
    • Be careful of the wires attaching the power button and the control buttons. Show extreme caution to ensure the button is not damaged.
    • Lift the screen assembly from the plastic housing from the corners.
  5. HP w2216h Power Supply Replacement: passo 5, imagem 1 %32 HP w2216h Power Supply Replacement: passo 5, imagem 2 %32
    • Remove the 4 connectors from the left side of the monitor on the back.
  6. HP w2216h Power Supply Replacement: passo 6, imagem 1 %32 HP w2216h Power Supply Replacement: passo 6, imagem 2 %32 HP w2216h Power Supply Replacement: passo 6, imagem 3 %32
    • Lift the gray tape of the top of the monitor to expose the ribbon cable.
    • Remove the ribbon cable by sliding the connector towards the center of the screen assembly.
    • Lift the reflective tape next to the gray tape.
  7. HP w2216h Power Supply Replacement: passo 7, imagem 1 %32 HP w2216h Power Supply Replacement: passo 7, imagem 2 %32 HP w2216h Power Supply Replacement: passo 7, imagem 3 %32
    • Remove the 4 PH1 8mm Philips round screws on the outer edge of the screen's assembly.
    • Lift the screen from the screen assembly.
  8. HP w2216h Power Supply Replacement, Power Supply: passo 8, imagem 1 %32
    • Monitor power supplies can be dangerous. Read ifixit's monitor safety guide before working with power supplies.
    • Remove the cables connecting the power supply to the display port.
  9. HP w2216h Power Supply Replacement: passo 9, imagem 1 %32
    • Remove the four 8mm Phillips #000 head screws connecting the power supply to the screen assembly.
  10. HP w2216h Power Supply Replacement: passo 10, imagem 1 %32
    • Lift the power supply vertically out of the screen assembly
Conclusão
Uma outra pessoa concluiu este guia.
Branflakes222
Membro desde: 03/25/16
399 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-1, Miles Spring 2016 Membro de UMass Dartmouth, Team 1-1, Miles Spring 2016
UMASSD-MILES-S16S1G1
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 808
