Ir para o conteúdo principal
HP w2216h Power Button Replacement
O que você precisa
  1. HP w2216h Power Button Replacement, Power Button: passo 1, imagem 1 %32 HP w2216h Power Button Replacement, Power Button: passo 1, imagem 2 %32 HP w2216h Power Button Replacement, Power Button: passo 1, imagem 3 %32
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  2. HP w2216h Power Button Replacement: passo 2, imagem 1 %32
    • Do not pull the screen away to hard, this could snap the power cable.
    • Remove the power button from the top of the plastic frame.
  3. HP w2216h Power Button Replacement: passo 3, imagem 1 %32
    • Remove the power cable by carefully sliding it out of it's plug.
    • Check if there is any tear or fray in the cable.
Conclusão
Sadeq Taha
Membro desde: 03/25/16
219 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-1, Miles Spring 2016 Membro de UMass Dartmouth, Team 1-1, Miles Spring 2016
UMASSD-MILES-S16S1G1
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 856
