Ir para o conteúdo principal
HP w2216h Control Buttons Replacement
O que você precisa
  1. HP w2216h Control Buttons Replacement, Control Buttons: passo 1, imagem 1 %32
    • Make sure you are grounded, the power supply is not connected, and you are wearing safety goggles.
    • Remove the four 12 mm Phillips #000 screws on the back panel.
  2. HP w2216h Control Buttons Replacement: passo 2, imagem 1 %32 HP w2216h Control Buttons Replacement: passo 2, imagem 2 %32
    • Remove the two 12 mm Phillips #000 screws above stand mounting bracket.
    • Using a Phillips #1 with the 150 mm flexible extension remove 1 Phillips #1 screw under the stand mounting bracket.
    • Stand will easily pull off.
  3. HP w2216h Control Buttons Replacement: passo 3, imagem 1 %32 HP w2216h Control Buttons Replacement: passo 3, imagem 2 %32 HP w2216h Control Buttons Replacement: passo 3, imagem 3 %32
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  4. HP w2216h Control Buttons Replacement: passo 4, imagem 1 %32
    • Lift the screen assembly from the plastic housing from the corners.
  5. HP w2216h Control Buttons Replacement: passo 5, imagem 1 %32
    • Remove the plastic buttons from the contacts
  6. HP w2216h Control Buttons Replacement: passo 6, imagem 1 %32 HP w2216h Control Buttons Replacement: passo 6, imagem 2 %32
    • Remove the wire connecting the contacts to the screen assembly.
Conclusão
Uma outra pessoa concluiu este guia.
Patrick Aucoin
Membro desde: 03/25/16
221 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-1, Miles Spring 2016 Membro de UMass Dartmouth, Team 1-1, Miles Spring 2016
UMASSD-MILES-S16S1G1
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 557
