Ir para o conteúdo principal
HP rp5700 Repair iOS battery Replacement
  1. HP rp5700 Repair iOS battery Replacement, Cover Removal: passo 1, imagem 1 %32
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Repair iOS battery Replacement: passo 2, imagem 1 %32 HP rp5700 Repair iOS battery Replacement: passo 2, imagem 2 %32
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. HP rp5700 Repair iOS battery Replacement: passo 3, imagem 1 %32 HP rp5700 Repair iOS battery Replacement: passo 3, imagem 2 %32 HP rp5700 Repair iOS battery Replacement: passo 3, imagem 3 %32
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
  4. HP rp5700 Repair iOS battery Replacement, iOS Battery: passo 4, imagem 1 %32 HP rp5700 Repair iOS battery Replacement, iOS Battery: passo 4, imagem 2 %32 HP rp5700 Repair iOS battery Replacement, iOS Battery: passo 4, imagem 3 %32
    • Press tab on the left side of the battery with your finger to release the battery from its position.
    • The battery should pop up out off its socket easily.
    • Once the battery has been removed, the BIOS is reset. Replace the battery back into its socket to complete the reset.
Conclusão
Uma outra pessoa concluiu este guia.
Alyssa Briones
Membro desde: 01/21/14
1.720 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 6-23, Maness Winter 2014 Membro de Cal Poly, Team 6-23, Maness Winter 2014
CPSU-MANESS-W14S6G23
Membros da 4
Autoria de 9 guias
2 comentários
Hello.
I followed the above steps on an HP rp5700 desktop. Now the computer time and date is set back to 2000. I have entered setup to change date and time. However, the date and time does not change as I navigate date and time…. no change at all. I have changed this before on other rp5700 desktops but this just wont change.
Someone out there HELP.
Regards.
Turk.
turk.gaonnwe - Responder
I did this for my HP rp5700 desktop, but it did not remedy my situation of after start-up, my icons do not show up. Just a blue windows logo screen. The start button is visible, along with the date/time, but nothing else. Let it sit overnight and the same thing is shown the next morning. Is this Windows Explorer related? If so, what can I do to fix it?
rrsull - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Duração total: 2,009
