Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The hard drive is the component that provides information storage for the computer. Use caution when handling the hard drive. Any type of shock to the drive could cause hard drive failure.
Make sure the computer is unplugged.
Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
Set the desktop down horizontally with the front side facing you.
Using your right hand, grip the CD drive and lift it up to a 90 degree position.
8 outras pessoas executaram este guia.
