Ir para o conteúdo principal
HP rp5700 Hard Drive Replacement
  1. HP rp5700 Hard Drive Replacement, Cover Removal: passo 1, imagem 1 %32
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Hard Drive Replacement: passo 2, imagem 1 %32 HP rp5700 Hard Drive Replacement: passo 2, imagem 2 %32
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. HP rp5700 Hard Drive Replacement: passo 3, imagem 1 %32 HP rp5700 Hard Drive Replacement: passo 3, imagem 2 %32 HP rp5700 Hard Drive Replacement: passo 3, imagem 3 %32
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
  4. HP rp5700 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 HP rp5700 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Using your right hand, grip the CD drive and lift it up to a 90 degree position.
  5. HP rp5700 Hard Drive Replacement: passo 5, imagem 1 %32 HP rp5700 Hard Drive Replacement: passo 5, imagem 2 %32
    • Use your hand, whichever you prefer, to grip the two cords on the CD drive and remove the two cords by pulling up.
    • Repeat the same process to remove the two cords connected to the Hard Drive.
  6. HP rp5700 Hard Drive Replacement: passo 6, imagem 1 %32
    • Use your right index finger to pull forward the green flap on the side of the hard drive.
    • At the same time as you are lifting the green flap, use your left hand to lift the hard drive up and out.
Conclusão
8 outras pessoas executaram este guia.
Alyssa Briones
Membro desde: 01/21/14
1.699 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 6-23, Maness Winter 2014 Membro de Cal Poly, Team 6-23, Maness Winter 2014
CPSU-MANESS-W14S6G23
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 28
Duração total: 3,754
