Ir para o conteúdo principal
HP iPAQ h4155 LCD screen replacement
O que você precisa
  1. HP iPAQ h4155 LCD screen replacement, Battery: passo 1, imagem 1 %32
    • While sliding the silver release tab up, simultaneously lift the cover up from the left side.
  2. HP iPAQ h4155 LCD screen replacement: passo 2, imagem 1 %32
    • Push the tab left to right to remove the cover.
  3. HP iPAQ h4155 LCD screen replacement: passo 3, imagem 1 %32
    • Now, lift the battery up and away from the device to remove it.
  4. HP iPAQ h4155 LCD screen replacement, Back Case: passo 4, imagem 1 %32
    • Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
  5. HP iPAQ h4155 LCD screen replacement: passo 5, imagem 1 %32
    • Remove the single black screw that is located beneath the HP sticker with the T5 Torx Screwdriver.
  6. HP iPAQ h4155 LCD screen replacement: passo 6, imagem 1 %32 HP iPAQ h4155 LCD screen replacement: passo 6, imagem 2 %32
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. HP iPAQ h4155 LCD screen replacement: passo 7, imagem 1 %32
    • Remove the back case.
  8. HP iPAQ h4155 LCD screen replacement, Face Plate: passo 8, imagem 1 %32
    • Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
  9. HP iPAQ h4155 LCD screen replacement: passo 9, imagem 1 %32 HP iPAQ h4155 LCD screen replacement: passo 9, imagem 2 %32
    • Next, unlock and remove the ribbon cable.
    • Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
    • The bar, the connector, and the cable are fragile components that are easily broken.
  10. HP iPAQ h4155 LCD screen replacement: passo 10, imagem 1 %32 HP iPAQ h4155 LCD screen replacement: passo 10, imagem 2 %32
    • Next, remove the wire from the bottom of the mother board.
    • The easiest method is to use metal tweezers and grip the plug closest to the connector.
    • Make sure all the connections are properly disconnected before separation from the motherboard.
  11. HP iPAQ h4155 LCD screen replacement: passo 11, imagem 1 %32
    • Next, use a plastic removal tool and separate the silver front case from the black frame.
  12. HP iPAQ h4155 LCD screen replacement, Touch LCD Screen: passo 12, imagem 1 %32 HP iPAQ h4155 LCD screen replacement, Touch LCD Screen: passo 12, imagem 2 %32
    • Now that the front cover is removed we can detach the screen
    • Remove the ribbon connector by pulling gently on the silver top. It will snap off the mother board.
    • The ribbon cable and connector can be easily removed if you genetly lift up the motherboard to create a small gap
  13. HP iPAQ h4155 LCD screen replacement: passo 13, imagem 1 %32 HP iPAQ h4155 LCD screen replacement: passo 13, imagem 2 %32 HP iPAQ h4155 LCD screen replacement: passo 13, imagem 3 %32
    • Now the screen can be removed
Conclusão
Uma outra pessoa concluiu este guia.
John Pagliero
Membro desde: 01/27/11
942 Reputação
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,532
