O que você precisa
While sliding the silver release tab up, simultaneously lift the cover up from the left side.
Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
Remove the 4 screws along the bottom of the faceplate
They are #00 Philips head screws
once the joypad key have been removed use the tweezers to carefully maneuver the wire out of its clip releasing the battery
4 outras pessoas concluíram este guia.
Um comentário
This guide is AWESOME.. Thanks! I have an iPAQ 1945 h1900, but this guide was the exact same for my device. I got as far as the taking the battery out without removing the 5th screw beneath the "warranty void" sticker. My only issue--do you know where to get the replacement battery?
