Ir para o conteúdo principal
Introdução
This step-by-step guide illustrates how to remove and replace the back case of a Pocket PC.
Peças
Nenhum componente especificado.
  1. Slide the silver release tab up and simultaneously lift the cover up from the left side.
    • Slide the silver release tab up and simultaneously lift the cover up from the left side.
  2. Push the tab from left to right to remove the cover.
    • Push the tab from left to right to remove the cover.
  3. Now lift the battery up and away from the device to remove it.
    • Now lift the battery up and away from the device to remove it.
  4. Remove the four silver screws (T5 x .25 in).
    • Remove the four silver screws (T5 x .25 in).
  5. Remove the single black screw (T5 x .125 in) beneath the HP sticker.
    • Remove the single black screw (T5 x .125 in) beneath the HP sticker.
  6. Next, use your plastic removal tool to separate the gray back from the black center piece. For better results, start the separation at the corner piece.
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. Remove the back case.
    • Remove the back case.
Conclusão
3 outras pessoas concluíram este guia.
John Pagliero
Membro desde: 27/01/2011
942 Reputação
7 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 772
