Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the HP iPAQ HW6515 over with the screen facing down.
Take the back cover off by pressing on the small silver button while pulling back then up on the case.
Place the back of the case aside for now.
Unscrew the four screws using the T6 hexagonal star screwdriver.
Unscrew the middle screw using the Phillips 00 screwdriver.
Use the plastic opening tool to pry apart the covers along the bottom of the phone.
Slide the plastic opening tool along the seam until the two halves of the case separate.
Gently pull off the black rubber square covering the LED light.
Wedge the plastic opening tool under the LED to pop it out and expose its wire.
Using your index finger and thumb, unplug the wire from the phone and remove the LED.
Uma outra pessoa concluiu este guia.
