Introdução
Is your screen for your HP iPAQ H3850 cracked or not working? Don't worry, you can easily replace the screen using this guide.
The screen is a component that lets you see what you are doing on the iPAQ. It might be hard to see what is happening on the screen if it is cracked.
Before beginning this repair, make sure that the iPAQ is turned off.
O que você precisa
To begin the disassembly of the device, place it on a flat surface with the screen facing down.
Uma outra pessoa concluiu este guia.
