Ir para o conteúdo principal
HP iPAQ H2200 motherbaord replacement
O que você precisa
  1. HP iPAQ H2200 motherbaord replacement, Battery: passo 1, imagem 1 %32
    • Press and slide the battery cover tab to remove battery cover.
  2. HP iPAQ H2200 motherbaord replacement: passo 2, imagem 1 %32 HP iPAQ H2200 motherbaord replacement: passo 2, imagem 2 %32
    • Pull on the black tab to lift the battery out of the battery compartment.
  3. HP iPAQ H2200 motherbaord replacement, Main Board: passo 3, imagem 1 %32
    • Remove the stylus by sliding it out of the slot.
  4. HP iPAQ H2200 motherbaord replacement: passo 4, imagem 1 %32
    • Remove the CF card by sliding it out of the slot at the top of the device.
  5. HP iPAQ H2200 motherbaord replacement: passo 5, imagem 1 %32
    • Press down and push the black side strips toward the top of the device to remove them.
  6. HP iPAQ H2200 motherbaord replacement: passo 6, imagem 1 %32 HP iPAQ H2200 motherbaord replacement: passo 6, imagem 2 %32 HP iPAQ H2200 motherbaord replacement: passo 6, imagem 3 %32
    • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
  7. HP iPAQ H2200 motherbaord replacement: passo 7, imagem 1 %32 HP iPAQ H2200 motherbaord replacement: passo 7, imagem 2 %32
    • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
  8. HP iPAQ H2200 motherbaord replacement: passo 8, imagem 1 %32
    • Open the LCD connector, where the orange strip attaches to the main board.
  9. HP iPAQ H2200 motherbaord replacement: passo 9, imagem 1 %32
    • Carefully remove the orange LCD strip from the connector.
  10. HP iPAQ H2200 motherbaord replacement: passo 10, imagem 1 %32
    • Unscrew the 2 screws located at each top corner of the main board.
  11. HP iPAQ H2200 motherbaord replacement: passo 11, imagem 1 %32
    • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
Conclusão
4 outras pessoas executaram este guia.
Tyler Andrews
Membro desde: 01/13/10
209 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 4-12, Forte Winter 2010 Membro de Cal Poly, Team 4-12, Forte Winter 2010
CPSU-FORTE-W10S4G12
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 4,615
