Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Press and slide the battery cover tab to remove battery cover.
Pull on the black tab to lift the battery out of the battery compartment.
Remove the CF card by sliding it out of the slot at the top of the device.
Press down and push the black side strips toward the top of the device to remove them.
Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
Open the LCD connector, where the orange strip attaches to the main board.
Carefully remove the orange LCD strip from the connector.
Unscrew the 2 screws located at each top corner of the main board.
Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
Unscrew the two bottom screws on LCD screen that were previously located under the main board.
Press on side tabs to loosen and remove the LCD screen.
Remove the faceplate by unscrewing the green screw located on the top right of the front faceplate.
