Ir para o conteúdo principal
HP eStation Zeen Motherboard Replacement
O que você precisa
  1. HP eStation Zeen Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 HP eStation Zeen Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 HP eStation Zeen Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the screw caps using the metal spudger.
    • Remove the four 6mm Phillips screws using the Phillips #0 screwdriver.
  2. HP eStation Zeen Motherboard Replacement: passo 2, imagem 1 %32 HP eStation Zeen Motherboard Replacement: passo 2, imagem 2 %32 HP eStation Zeen Motherboard Replacement: passo 2, imagem 3 %32
    • Unclip each side of the back cover by inserting the plastic opening tool and sliding it along the edge.
    • Remove the back panel by lifting the panel away from the device.
  3. HP eStation Zeen Motherboard Replacement: passo 3, imagem 1 %32
    • Disconnect battery clip with plastic opening tool.
    • The clip is very fragile.
  4. HP eStation Zeen Motherboard Replacement: passo 4, imagem 1 %32
    • Disconnect the speaker terminal with the plastic opening tool.
  5. HP eStation Zeen Motherboard Replacement: passo 5, imagem 1 %32
    • Disconnect the the volume button clip with metal spudger tool.
    • The clip is fragile.
  6. HP eStation Zeen Motherboard Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Disconnect the ground wire from the motherboard with tweezers.
  7. HP eStation Zeen Motherboard Replacement: passo 7, imagem 1 %32 HP eStation Zeen Motherboard Replacement: passo 7, imagem 2 %32
    • Remove the two 6mm Phillips screws with Phillips #0 screwdriver.
  8. HP eStation Zeen Motherboard Replacement: passo 8, imagem 1 %32 HP eStation Zeen Motherboard Replacement: passo 8, imagem 2 %32
    • Pry off the clips that hold the motherboard down with the plastic spudger.
  9. HP eStation Zeen Motherboard Replacement: passo 9, imagem 1 %32 HP eStation Zeen Motherboard Replacement: passo 9, imagem 2 %32
    • Lift motherboard up to expose the ribbons on the back.
    • Lift the grey tabs to disconnect the ribbons with plastic spudger.
Conclusão
Uma outra pessoa concluiu este guia.
dalton hale
Membro desde: 09/26/16
503 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 16-4, Eyestone Fall 2016 Membro de USF Tampa, Team 16-4, Eyestone Fall 2016
USFT-EYESTONE-F16S16G4
4 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 575
