Ir para o conteúdo principal
HP eStation Zeen Ground Wire Replacement
O que você precisa
  1. HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: passo 1, imagem 1 %32 HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: passo 1, imagem 2 %32 HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: passo 1, imagem 3 %32
    • Remove the screw caps using a metal spudger.
    • Remove the four 6 mm screws using a Phillips #0 screwdriver.
  2. HP eStation Zeen Ground Wire Replacement: passo 2, imagem 1 %32 HP eStation Zeen Ground Wire Replacement: passo 2, imagem 2 %32 HP eStation Zeen Ground Wire Replacement: passo 2, imagem 3 %32
    • Insert a plastic opening tool into the case seam and slide it along the edges.
    • Lift and remove the back panel from the device.
  3. HP eStation Zeen Ground Wire Replacement: passo 3, imagem 1 %32
    • Carefully disconnect the battery clip using small plastic spudger.
    • The clip is extremely fragile.
  4. HP eStation Zeen Ground Wire Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to disconnect the ground wire from motherboard terminal.
  5. HP eStation Zeen Ground Wire Replacement: passo 5, imagem 1 %32
    • Use a soldering iron to remove the ground wire.
    • Avoid touching or heating the motherboard.
Conclusão
dalton hale
Membro desde: 09/26/16
503 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 16-4, Eyestone Fall 2016 Membro de USF Tampa, Team 16-4, Eyestone Fall 2016
USFT-EYESTONE-F16S16G4
4 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 392
