Ir para o conteúdo principal
HP dv7-4065x Keyboard Replacement
  1. HP dv7-4065x Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove the battery from the laptop.
  2. HP dv7-4065x Keyboard Replacement: passo 2, imagem 1 %32
    • Move the switch in the battery compartment.
  3. HP dv7-4065x Keyboard Replacement: passo 3, imagem 1 %32
    • Carefully flip up the keyboard panel.
    • Don't pull far on the keyboard. It will still be connected to the laptop via ribbon cables.
  4. HP dv7-4065x Keyboard Replacement: passo 4, imagem 1 %32
    • Lift the retaining flap on the keyboard cable ZIF connector.
    • Carefully pull the ribbon cable from its socket on the motherboard.
Conclusão
Mikayla Tabora
Membro desde: 03/08/17
201 Reputação
Autoria de 2 guias
Equipe
Um comentário
First you need to unscrew 2 screws under the HDD cover
christo04 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 1,625
