Introdução
If your wifi isn't working, it might just be a loose connection to your wireless card. Follow this guide to replace your wireless card.
O que você precisa
Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
Locate the wireless card and the two wires attached to it.
Using a plastic spudger tool, carefully lift up on each wire connecting the card to unsnap the connectors.
Uma outra pessoa concluiu este guia.
