Ir para o conteúdo principal
HP dv5-1125nr Disk Drive Replacement
O que você precisa
  1. HP dv5-1125nr Disk Drive Replacement, Battery: passo 1, imagem 1 %32
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Disk Drive Replacement: passo 2, imagem 1 %32
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Disk Drive Replacement, Disk Drive: passo 3, imagem 1 %32 HP dv5-1125nr Disk Drive Replacement, Disk Drive: passo 3, imagem 2 %32
    • Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
    • Remove the CMOS panel cover.
  4. HP dv5-1125nr Disk Drive Replacement: passo 4, imagem 1 %32 HP dv5-1125nr Disk Drive Replacement: passo 4, imagem 2 %32 HP dv5-1125nr Disk Drive Replacement: passo 4, imagem 3 %32
    • The optical drive is now ready for removal. Using a plastic removal tool, lift the optical drive away from your computer.
    • Using your hands, slide the remainder of the drive out of the computer.
Conclusão
Nick Loey
Membro desde: 04/01/14
1.676 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 9-15, Regan Spring 2014 Membro de Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 715
