Introdução
Removing the battery is usually the first step to reaching the guts of any laptop. HP has utilized a simple one-switch release system to aid in the removal of the battery.
O que você precisa
To reassemble your device, follow these instructions in reverse order. Note the release switch does not need to be held down to replace the battery.
4 outras pessoas executaram este guia.
2 comentários
Can I return a battery if it does not fit? GLOPAM2013@YAHOO.COM
what is your return policy?
