Introdução
Removing the battery is usually the first step to reaching the guts of any laptop. HP has utilized a simple one-switch release system to aid in the removal of the battery.
Ferramentas
Não são necessárias ferramentas.
  1. Ensure your computer is shut down.
    • Ensure your computer is shut down.
    • Removing the battery while the laptop is still on may corrupt your files.
    • Remove any power adapters and cords connected to the laptop body.
    • Turn the computer over so the bottom is facing up.
    • These pictures show no battery, but your battery should still be in your computer at this point.
  2. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. The battery release is below the bottom right corner of the battery bay.
    • The battery release is below the bottom right corner of the battery bay.
    • Slide the switch to the right until the release clicks.
  4. Remove the battery.
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
Conclusão
To reassemble your device, follow these instructions in reverse order. Note the release switch does not need to be held down to replace the battery.
4 outras pessoas concluíram este guia.
Nick Loey
1.565 reputação
8 Guides authored
Equipe
Cal Poly, Team 9-15, Regan Spring 2014 Membro de Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Membros
10 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Todo: 827
