Introdução
Here is some information about what to do if your computer gives you a message saying "Low Disk Space." If you turn on your computer and it won't boot properly, read this troubleshooting guide. If you determine that you need to replace or upgrade your hard drive, follow this replacement guide!
O que você precisa
Flip the laptop over.
Slide the lever with the battery symbol beside it firmly until the battery pops out.
Remove the battery from the laptop.
Slide the right lever firmly to the right.
Slide the cover towards yourself to remove it.
Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
Remove the two 3mm screws on either side of the device with a Phillips #0 screwdriver to remove the drive caddy.
13 outras pessoas executaram este guia.
3 comentários
how hard disk i can buy for my zbook 15?
thanks
