Ir para o conteúdo principal
HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement
O que você precisa
  1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: passo 1, imagem 1 %32 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: passo 1, imagem 2 %32 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: passo 1, imagem 3 %32
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: passo 2, imagem 1 %32 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: passo 2, imagem 2 %32
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: passo 3, imagem 1 %32 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: passo 3, imagem 2 %32 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: passo 3, imagem 3 %32
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: passo 4, imagem 1 %32 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: passo 4, imagem 2 %32
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: passo 5, imagem 1 %32 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: passo 5, imagem 2 %32 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: passo 5, imagem 3 %32
    • Grasp the trigger with one hand while pushing against the outer wall of the shell.
    • Apply pressure, pulling the wall away from the trigger.
    • Remove the trigger starting from the freed edge.
    • The spring-rod assembly can easily come apart. Inserting the large end first during reassembly may make the process easier.
Conclusão
4 outras pessoas executaram este guia.
Clement Cheung
Membro desde: 01/24/19
643 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S18-G5, White Winter 2019 Membro de Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 1,775
