Introdução
This guide will go over how to replace the small circuit board in your device.
You will need to have a new circuit board to replace the old one with.
Be careful around the edges of the circuit board as they can be sharp and you could possibly cut yourself.
O que você precisa
Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
Uma outra pessoa concluiu este guia.
1Comentário do guia
Where would I be able to buy a replacement small board?
