Ir para o conteúdo principal
HP TouchSmart 15-r015dx Screen Replacement
O que você precisa
  1. HP TouchSmart 15-r015dx Screen Replacement, Screen: passo 1, imagem 1 %32 HP TouchSmart 15-r015dx Screen Replacement, Screen: passo 1, imagem 2 %32 HP TouchSmart 15-r015dx Screen Replacement, Screen: passo 1, imagem 3 %32
    • Acquire the metal spudger and a Precision Magnetized Driver with J1 size bit.
    • Flip your HP TouchSmart 15 over.
  2. HP TouchSmart 15-r015dx Screen Replacement: passo 2, imagem 1 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 2, imagem 2 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 2, imagem 3 %32
    • Locate tabs on the underside of the laptop.
    • Push both tabs towards the center of the laptop and pull away to remove battery.
  3. HP TouchSmart 15-r015dx Screen Replacement: passo 3, imagem 1 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 3, imagem 2 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 3, imagem 3 %32
    • Take the sharp end of the pry tool and pop out the black screw cover.
    • Repeat on opposite side.
  4. HP TouchSmart 15-r015dx Screen Replacement: passo 4, imagem 1 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 4, imagem 2 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 4, imagem 3 %32
    • Take the Precision Magnetized Driver with J1 size bit and unscrew the screw.
  5. HP TouchSmart 15-r015dx Screen Replacement: passo 5, imagem 1 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 5, imagem 2 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 5, imagem 3 %32
    • Using the pry tool, begin to separate the touchscreen from the plastic backing.
  6. HP TouchSmart 15-r015dx Screen Replacement: passo 6, imagem 1 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 6, imagem 2 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 6, imagem 3 %32
    • Close the laptop and flip it over once again.
    • Continue to pry the touchscreen from the plastic backing in the hinged area of the laptop.
  7. HP TouchSmart 15-r015dx Screen Replacement: passo 7, imagem 1 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 7, imagem 2 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 7, imagem 3 %32
    • Flip over the laptop and open it.
    • Pull up on the separated touchscreen while pulling it away from the plastic backing.
    • Be careful while laying down the touchscreen to not pull the connection point.
    • Lay the touchscreen on the keyboard facedown.
  8. HP TouchSmart 15-r015dx Screen Replacement: passo 8, imagem 1 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 8, imagem 2 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 8, imagem 3 %32
    • Locate the connection point.
    • Slowly and carefully peel off.
  9. HP TouchSmart 15-r015dx Screen Replacement: passo 9, imagem 1 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 9, imagem 2 %32
    • Isolate the touchscreen from the keyboard.
  10. HP TouchSmart 15-r015dx Screen Replacement: passo 10, imagem 1 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 10, imagem 2 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 10, imagem 3 %32
    • Begin by peeling off the black adhesive tape using the pry tool.
    • Once adhesive tape is removed, use the pry tool to remove the tab in the corner. Repeat in each corner.
  11. HP TouchSmart 15-r015dx Screen Replacement: passo 11, imagem 1 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 11, imagem 2 %32 HP TouchSmart 15-r015dx Screen Replacement: passo 11, imagem 3 %32
    • Using the sharp end of the pry tool, separate the plastic from the screen.
  12. HP TouchSmart 15-r015dx Screen Replacement: passo 12, imagem 1 %32
    • Now it is time to reassemble your device with a new screen.
Conclusão
3 outras pessoas executaram este guia.
Um comentário
Amazing work. I would not change a thing.
Dan Hartzell - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 1,217
