Introdução
The HP TouchSmart 15-r015dx has a standard laptop motherboard.
O que você precisa
Flip over to view the bottom of the laptop in order to gain access the battery and the DVD±RW Drive.
There is one screw holding the DVD±RW Drive in place. Use the #00 screwdriver to remove the screw.
Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
Flip the laptop over to view the bottom and remove the remaining screws from the bottom.
There are 3 screws holding the motherboard in place.
Unscrew the screws to release the motherboard.
4 outras pessoas executaram este guia.
Um comentário
I need to buy this motherboard online
How can i find it?
