Ir para o conteúdo principal
HP TouchSmart 15-r015dx Keyboard Replacement
O que você precisa
  1. HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
    • One of the screws lies in the label.
  2. HP TouchSmart 15-r015dx Keyboard Replacement: passo 2, imagem 1 %32 HP TouchSmart 15-r015dx Keyboard Replacement: passo 2, imagem 2 %32 HP TouchSmart 15-r015dx Keyboard Replacement: passo 2, imagem 3 %32
    • Flip the laptop over to view the top and lift the screen up.
    • There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer.
    • Do NOT pull the keyboard up more than 2-3 inches as there is a film-material connecting the keyboard to the laptop.
  3. HP TouchSmart 15-r015dx Keyboard Replacement: passo 3, imagem 1 %32 HP TouchSmart 15-r015dx Keyboard Replacement: passo 3, imagem 2 %32 HP TouchSmart 15-r015dx Keyboard Replacement: passo 3, imagem 3 %32
    • There is a small black latch holding the film-material in place.
    • Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard.
    • There are tiny prongs on the ribbon; it must be carefully removed and upon re-installation the prongs must be lined up exactly in each tiny track in order for the keyboard to work.
Conclusão
Jacob Kleinsorge
Membro desde: 01/30/15
2.093 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 16-4, Watkins Winter 2015 Membro de USF Tampa, Team 16-4, Watkins Winter 2015
USFT-WATKINS-W15S16G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 3,002
