Ir para o conteúdo principal
HP TouchSmart 15-r015dx Battery Replacement
  1. HP TouchSmart 15-r015dx Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn off your laptop.
    • Ensure your laptop is off. Removing the battery while it is on may harm your laptop or yourself.
    • Flip over to view the bottom of the laptop in order to gain access the battery and the DVD±RW Drive.
  2. HP TouchSmart 15-r015dx Battery Replacement: passo 2, imagem 1 %32
    • There are two battery release switches circled.
  3. HP TouchSmart 15-r015dx Battery Replacement: passo 3, imagem 1 %32
    • slide release switches inward towards each other to release battery.
  4. HP TouchSmart 15-r015dx Battery Replacement: passo 4, imagem 1 %32
    • after sliding the release switches, pull battery towards yourself to remove battery.
Conclusão
Jacob Kleinsorge
Membro desde: 01/30/15
2.093 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 16-4, Watkins Winter 2015 Membro de USF Tampa, Team 16-4, Watkins Winter 2015
USFT-WATKINS-W15S16G4
Membros da 4
Autoria de 6 guias
Um comentário
I did all the steps but the laptop didn't turn on at all. I then unhooked the power, removed the new replacement battery, and plugged the power back in it turned on without the battery but it won't turn on with the new battery in it. What am I doing wrong? Thx for you time.
Sincerely, Don Mattia
ddavonn - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 28
Duração total: 2,172
