Ir para o conteúdo principal
HP Stream x360 11-p015wm Speaker Replacement
O que você precisa
  1. HP Stream x360 11-p015wm Speaker Replacement, Back Cover: passo 1, imagem 1 %32 HP Stream x360 11-p015wm Speaker Replacement, Back Cover: passo 1, imagem 2 %32
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Speaker Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    JIS Driver Set
    $19.99
    Comprar
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Speaker Replacement: passo 3, imagem 1 %32 HP Stream x360 11-p015wm Speaker Replacement: passo 3, imagem 2 %32
    iFixit Opening Tool
    $1.99
    Comprar
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Speaker Replacement: passo 4, imagem 1 %32 HP Stream x360 11-p015wm Speaker Replacement: passo 4, imagem 2 %32
    $3.99
    Comprar
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Speaker Replacement, Speaker: passo 5, imagem 1 %32
    • Locate your speaker on the left and right ends of the front rear side of your laptop.
  6. HP Stream x360 11-p015wm Speaker Replacement: passo 6, imagem 1 %32 HP Stream x360 11-p015wm Speaker Replacement: passo 6, imagem 2 %32 HP Stream x360 11-p015wm Speaker Replacement: passo 6, imagem 3 %32
    • Use JIS J1 screwdriver to remove exposed screws on one or both of the speakers.
  7. HP Stream x360 11-p015wm Speaker Replacement: passo 7, imagem 1 %32
    • Unplug the speaker wire connected to the laptop.
  8. HP Stream x360 11-p015wm Speaker Replacement: passo 8, imagem 1 %32
    • Carefully remove the speaker from the laptop.
Conclusão
DaisyHaskell
Membro desde: 10/15/18
683 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S1-G2, Valliere Fall 2018 Membro de UMass Dartmouth, Team S1-G2, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G2
Membros da 4
Autoria de 6 guias
Um comentário
Hey, so is there any idea how to remove the memory on this laptop? I'm very new to disassembly and these guides are very useful for the laptop I have. Thanks!
j ! - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 162
