Ir para o conteúdo principal
HP Stream x360 11-p015wm Keyboard Replacement
O que você precisa
  1. HP Stream x360 11-p015wm Keyboard Replacement, Back Cover: passo 1, imagem 1 %32 HP Stream x360 11-p015wm Keyboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Keyboard Replacement: passo 2, imagem 1 %32
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Keyboard Replacement: passo 3, imagem 1 %32 HP Stream x360 11-p015wm Keyboard Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    iFixit Opening Tool
    $1.99
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Keyboard Replacement: passo 4, imagem 1 %32 HP Stream x360 11-p015wm Keyboard Replacement: passo 4, imagem 2 %32
    $3.99
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Keyboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
  6. HP Stream x360 11-p015wm Keyboard Replacement: passo 6, imagem 1 %32 HP Stream x360 11-p015wm Keyboard Replacement: passo 6, imagem 2 %32 HP Stream x360 11-p015wm Keyboard Replacement: passo 6, imagem 3 %32
    • Unplug the wire attaching to the battery to the motherboard using the tweezers.
    • Remove the battery.
  7. HP Stream x360 11-p015wm Keyboard Replacement: passo 7, imagem 1 %32 HP Stream x360 11-p015wm Keyboard Replacement: passo 7, imagem 2 %32
    • Remove the six 3.5 mm screws from the silver plate cover with screwdriver JIS #00.
    • Remove the silver plate cover.
  8. HP Stream x360 11-p015wm Keyboard Replacement: passo 8, imagem 1 %32 HP Stream x360 11-p015wm Keyboard Replacement: passo 8, imagem 2 %32
    • Remove the four 3.5 mm screws from the metal arm using the JIS #00 screwdriver.
  9. HP Stream x360 11-p015wm Keyboard Replacement: passo 9, imagem 1 %32 HP Stream x360 11-p015wm Keyboard Replacement: passo 9, imagem 2 %32 HP Stream x360 11-p015wm Keyboard Replacement: passo 9, imagem 3 %32
    • Detach all remaining wires from the motherboard using the tweezers.
  10. HP Stream x360 11-p015wm Keyboard Replacement: passo 10, imagem 1 %32 HP Stream x360 11-p015wm Keyboard Replacement: passo 10, imagem 2 %32
  11. HP Stream x360 11-p015wm Keyboard Replacement: passo 11, imagem 1 %32 HP Stream x360 11-p015wm Keyboard Replacement: passo 11, imagem 2 %32
    • Remove the six 3.5 mm screws from the motherboard using the JIS #00 screwdriver.
    • Remove the motherboard.
  12. HP Stream x360 11-p015wm Keyboard Replacement, Keyboard: passo 12, imagem 1 %32 HP Stream x360 11-p015wm Keyboard Replacement, Keyboard: passo 12, imagem 2 %32
    • Remove the three 6.5 mm screws from the second screen hinge and metal arm using the JIS #00 screwdriver.
    • Remove the metal bracket.
  13. HP Stream x360 11-p015wm Keyboard Replacement: passo 13, imagem 1 %32
    • Remove the two 3.5 mm screws from the small sideboard using the JIS #00 screwdriver.
  14. HP Stream x360 11-p015wm Keyboard Replacement: passo 14, imagem 1 %32 HP Stream x360 11-p015wm Keyboard Replacement: passo 14, imagem 2 %32
    • Use the blue plastic opening tool to pry up the silver keyboard cover.
    • Remove the keyboard cover.
  15. HP Stream x360 11-p015wm Keyboard Replacement: passo 15, imagem 1 %32 HP Stream x360 11-p015wm Keyboard Replacement: passo 15, imagem 2 %32
    • Remove the keyboard.
Conclusão
Megan Waxman
Membro desde: 11/11/19
160 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G3, Stella Fall 2019 Membro de IUPUI, Team S2-G3, Stella Fall 2019
IUPUI-STELLA-F19S2G3
3 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 270
