Ir para o conteúdo principal
HP Stream x360 11-p015wm Battery Replacement
O que você precisa
  1. HP Stream x360 11-p015wm Battery Replacement, Back Cover: passo 1, imagem 1 %32 HP Stream x360 11-p015wm Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Battery Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    JIS Driver Set
    $19.99
    Comprar
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Battery Replacement: passo 3, imagem 1 %32 HP Stream x360 11-p015wm Battery Replacement: passo 3, imagem 2 %32
    iFixit Opening Tool
    $1.99
    Comprar
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Battery Replacement: passo 4, imagem 1 %32 HP Stream x360 11-p015wm Battery Replacement: passo 4, imagem 2 %32
    $3.99
    Comprar
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Battery Replacement, Battery: passo 5, imagem 1 %32 HP Stream x360 11-p015wm Battery Replacement, Battery: passo 5, imagem 2 %32 HP Stream x360 11-p015wm Battery Replacement, Battery: passo 5, imagem 3 %32
    • Use the JIS J1 screwdriver to remove the 6.5 mm screws surrounding the battery.
  6. HP Stream x360 11-p015wm Battery Replacement: passo 6, imagem 1 %32 HP Stream x360 11-p015wm Battery Replacement: passo 6, imagem 2 %32 HP Stream x360 11-p015wm Battery Replacement: passo 6, imagem 3 %32
    • Using the iFixit tweezers, remove the cable connecting the battery to the motherboard.
    • Remove the wire located on the top side of the battery.
    • All connections should be removed. Simply remove the battery from the computer.
Conclusão
DaisyHaskell
Membro desde: 10/15/18
683 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S1-G2, Valliere Fall 2018 Membro de UMass Dartmouth, Team S1-G2, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 524
