Ir para o conteúdo principal
HP Stream x360 11-p010nr Battery Replacement
O que você precisa
  1. HP Stream x360 11-p010nr Battery Replacement, Battery: passo 1, imagem 1 %32 HP Stream x360 11-p010nr Battery Replacement, Battery: passo 1, imagem 2 %32 HP Stream x360 11-p010nr Battery Replacement, Battery: passo 1, imagem 3 %32
    • First, make sure the laptop is completely powered off and not charging to avoid electric shock.
    • Flip the laptop upside down then remove the seven 6.5 mm screws using a JIS J0 screwdriver.
    • Also remove the two 8.5 mm JIS J0 screws near the hinge of the laptop.
    • Peel back the two rubber feet near the hinge of the laptop to reveal and remove two more 8.5 mm JIS J0 screws.
    • The rubber feet near the speakers have no screws.
  2. HP Stream x360 11-p010nr Battery Replacement: passo 2, imagem 1 %32 HP Stream x360 11-p010nr Battery Replacement: passo 2, imagem 2 %32
    • After removing all the screws, slowly and carefully lift the back cover, exposing the internal components.
    • Be careful not to damage the blue strip when opening the back case.
  3. HP Stream x360 11-p010nr Battery Replacement: passo 3, imagem 1 %32 HP Stream x360 11-p010nr Battery Replacement: passo 3, imagem 2 %32 HP Stream x360 11-p010nr Battery Replacement: passo 3, imagem 3 %32
    • Carefully detach the blue strip that connects the back cover to the internals.
    • Make sure the blue tab is facing upwards when reassembling.
  4. HP Stream x360 11-p010nr Battery Replacement: passo 4, imagem 1 %32 HP Stream x360 11-p010nr Battery Replacement: passo 4, imagem 2 %32 HP Stream x360 11-p010nr Battery Replacement: passo 4, imagem 3 %32
    • Using the JIS J0 screwdriver, unscrew the 6.5 mm screws surrounding the battery.
  5. HP Stream x360 11-p010nr Battery Replacement: passo 5, imagem 1 %32
    • Carefully remove the surrounding wire away from the battery
  6. HP Stream x360 11-p010nr Battery Replacement: passo 6, imagem 1 %32 HP Stream x360 11-p010nr Battery Replacement: passo 6, imagem 2 %32 HP Stream x360 11-p010nr Battery Replacement: passo 6, imagem 3 %32
    • Lastly, unhook the clip connecting the battery to the motherboard by pushing it away from the slot.
    • At this point, everything should be disconnected, simply remove the battery. Be sure to maneuver around the wire that runs between the middle of the battery.
Conclusão
5 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S7-G4, Cagle Spring 2017 Membro de USF Tampa, Team S7-G4, Cagle Spring 2017
USFT-CAGLE-S17S7G4
Membros da 4
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 3,760
