Ir para o conteúdo principal
HP Stream 8 Motherboard Replacement
O que você precisa
  1. HP Stream 8 Motherboard Replacement, Midframe: passo 1, imagem 1 %32
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Motherboard Replacement: passo 2, imagem 1 %32
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Motherboard Replacement: passo 4, imagem 1 %32
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Motherboard Replacement, Front-Facing Camera: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
  6. HP Stream 8 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the front facing camera with tweezers.
  7. HP Stream 8 Motherboard Replacement, Rear-Facing Camera: passo 7, imagem 1 %32
    • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
  8. HP Stream 8 Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the back facing camera with the tweezers.
  9. HP Stream 8 Motherboard Replacement, Motherboard: passo 9, imagem 1 %32
    • Carefully remove the battery connector from the system board using the tweezers.
  10. HP Stream 8 Motherboard Replacement: passo 10, imagem 1 %32
    • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
  11. HP Stream 8 Motherboard Replacement: passo 11, imagem 1 %32
    • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
  12. HP Stream 8 Motherboard Replacement: passo 12, imagem 1 %32
    • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
  13. HP Stream 8 Motherboard Replacement: passo 13, imagem 1 %32
    • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
  14. HP Stream 8 Motherboard Replacement: passo 14, imagem 1 %32
    • Remove the motherboard from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Nick Miller
Membro desde: 04/11/16
669 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 34-14, Maness Spring 2016 Membro de Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Membros
Autoria de 12 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 19
Ao todo: 1,140
