Ir para o conteúdo principal
HP Stream 13-c110nr Touchpad Assembly Replacement
O que você precisa
  1. HP Stream 13-c110nr Touchpad Assembly Replacement, Keyboard Assembly: passo 1, imagem 1 %32
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr Touchpad Assembly Replacement: passo 2, imagem 1 %32
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr Touchpad Assembly Replacement: passo 3, imagem 1 %32 HP Stream 13-c110nr Touchpad Assembly Replacement: passo 3, imagem 2 %32 HP Stream 13-c110nr Touchpad Assembly Replacement: passo 3, imagem 3 %32
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr Touchpad Assembly Replacement: passo 4, imagem 1 %32 HP Stream 13-c110nr Touchpad Assembly Replacement: passo 4, imagem 2 %32 HP Stream 13-c110nr Touchpad Assembly Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr Touchpad Assembly Replacement: passo 5, imagem 1 %32
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr Touchpad Assembly Replacement: passo 6, imagem 1 %32 HP Stream 13-c110nr Touchpad Assembly Replacement: passo 6, imagem 2 %32 HP Stream 13-c110nr Touchpad Assembly Replacement: passo 6, imagem 3 %32
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr Touchpad Assembly Replacement: passo 7, imagem 1 %32
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr Touchpad Assembly Replacement: passo 8, imagem 1 %32 HP Stream 13-c110nr Touchpad Assembly Replacement: passo 8, imagem 2 %32
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr Touchpad Assembly Replacement: passo 9, imagem 1 %32 HP Stream 13-c110nr Touchpad Assembly Replacement: passo 9, imagem 2 %32
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr Touchpad Assembly Replacement: passo 10, imagem 1 %32
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr Touchpad Assembly Replacement, Touchpad Assembly: passo 11, imagem 1 %32 HP Stream 13-c110nr Touchpad Assembly Replacement, Touchpad Assembly: passo 11, imagem 2 %32
    • Place the Top Cover/Keyboard assembly face down with the front towards you.
  12. HP Stream 13-c110nr Touchpad Assembly Replacement: passo 12, imagem 1 %32 HP Stream 13-c110nr Touchpad Assembly Replacement: passo 12, imagem 2 %32
    • Remove the TouchPad cable.
  13. HP Stream 13-c110nr Touchpad Assembly Replacement: passo 13, imagem 1 %32
    • Remove two (2) Phillips P0 PM2.5x3.0 mm screws from Touchpad assembly.
    • Place two (2) screws on magnetic mat for reassembly.
  14. HP Stream 13-c110nr Touchpad Assembly Replacement: passo 14, imagem 1 %32 HP Stream 13-c110nr Touchpad Assembly Replacement: passo 14, imagem 2 %32 HP Stream 13-c110nr Touchpad Assembly Replacement: passo 14, imagem 3 %32
    • Use the plastic pick to pry up the black TouchPad cover from the blue top cover.
    • The TouchPad cover is molded to the Top Cover/Keyboard. Slight pressure must be maintained to release the cover.
    • A popping noise may be heard when prying the touchpad cover off of the top cover.
  15. HP Stream 13-c110nr Touchpad Assembly Replacement: passo 15, imagem 1 %32 HP Stream 13-c110nr Touchpad Assembly Replacement: passo 15, imagem 2 %32
    • Remove the Touchpad assembly from the device.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 248
