Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Close the device.
Remove AC adapter plug from electrical outlet.
Remove AC adapter from device.
Turn the device off.
Unplug all external devices from device.
Turn the device upside down with the back facing towards you.
Use a pick to remove the two (2) large computer feet along the back edge of the device.
Use a pick to remove the two (2) small computer feet.
Use a pick to remove the one (1) screw cover.
Place rubber computer feet in safe place for reassembly.
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95-
Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
Place the thirteen (13) screws on magnetic mat for reassembly.
Turn the device over with the front facing towards you.
Open the device as shown.
Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
Uma outra pessoa concluiu este guia.
