Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
The Top Cover/Keyboard guide will assist the user in opening the HP Stream 13-c110nr for further repairs. The guide is the initial guide for all repair activity.
  1. Close the device.
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. Turn the device upside down with the back facing towards you.
    • Turn the device upside down with the back facing towards you.
  3. Use a pick to remove the two (2) large computer feet along the back edge of the device. Use a pick to remove the two (2) small computer feet. Use a pick to remove the one (1) screw cover.
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws. Place the thirteen (13) screws on magnetic mat for reassembly. Place the thirteen (13) screws on magnetic mat for reassembly.
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  6. Turn the device over with the front facing towards you.
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  7. Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover. Do not completely remove the Keyboard/Top cover from the Bottom cover yet. Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  8. Disconnect the Touchpad cable.
    • Disconnect the Touchpad cable.
  9. Disconnect the Keyboard Cable. Disconnect the Keyboard Cable.
    • Disconnect the Keyboard Cable.
  10. Disconnect the Power connector cable. Disconnect the Power connector cable.
    • Disconnect the Power connector cable.
  11. Remove the Keyboard/Top Cover from the device.
    • Remove the Keyboard/Top Cover from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 70
