Introdução
This guide is designed to walk you through a step-by-step process of replacing the keyboard assembly on your device. The Keyboard Assembly guide will assist the user in opening the HP Stream 13-c110nr for further repairs. The guide is the initial guide for all repair activity.
O que você precisa
Close the device.
Remove AC adapter plug from electrical outlet.
Remove AC adapter from device.
Turn the device off.
Unplug all external devices from device.
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
Place the thirteen (13) screws on magnetic mat for reassembly.
Uma outra pessoa concluiu este guia.
