Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introdução
The Speaker assembly guide will assist the user in removal of the speaker assembly from the HP Stream 13-c110nr.
  1. Close the device.
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. Turn the device upside down with the back facing towards you.
    • Turn the device upside down with the back facing towards you.
  3. Use a pick to remove the two (2) large computer feet along the back edge of the device. Use a pick to remove the two (2) small computer feet. Use a pick to remove the one (1) screw cover.
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws. Place the thirteen (13) screws on magnetic mat for reassembly. Place the thirteen (13) screws on magnetic mat for reassembly.
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. Turn the device over with the front facing towards you.
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover. Do not completely remove the Keyboard/Top cover from the Bottom cover yet. Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. Disconnect the Touchpad cable.
    • Disconnect the Touchpad cable.
  8. Disconnect the Keyboard Cable. Disconnect the Keyboard Cable.
    • Disconnect the Keyboard Cable.
  9. Disconnect the Power connector cable. Disconnect the Power connector cable.
    • Disconnect the Power connector cable.
  10. Remove the Keyboard/Top Cover from the device.
    • Remove the Keyboard/Top Cover from the device.
  11. Use a pick to detach the Battery assembly cable. Use a pick to detach the Battery assembly cable.
    • Use a pick to detach the Battery assembly cable.
  12. Remove eight (8) Phillips P0 PM2.0x3.0 mm screws from Battery assembly. Place eight (8) screws on magnetic mat for reassembly.
    • Remove eight (8) Phillips P0 PM2.0x3.0 mm screws from Battery assembly.
    • Place eight (8) screws on magnetic mat for reassembly.
  13. Remove Battery Assembly from device.
    • Remove Battery Assembly from device.
  14. Use a pick to disconnect the Speaker Cable from the System Board. Use a pick to disconnect the Speaker Cable from the System Board.
    • Use a pick to disconnect the Speaker Cable from the System Board.
  15. Remove two (2) P0 PM 2.0 x 3.0  mm screws from speaker assembly. Place two (2) screws on magnetic mat for reassembly.
    • Remove two (2) P0 PM 2.0 x 3.0 mm screws from speaker assembly.
    • Place two (2) screws on magnetic mat for reassembly.
  16. Remove the Speakers from the device.
    • Remove the Speakers from the device.
Conclusão
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 34
