Ir para o conteúdo principal
HP Stream 13-c110nr Motherboard Replacement
O que você precisa
  1. HP Stream 13-c110nr Motherboard Replacement, Keyboard Assembly: passo 1, imagem 1 %32
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr Motherboard Replacement: passo 2, imagem 1 %32
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr Motherboard Replacement: passo 3, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement: passo 3, imagem 2 %32 HP Stream 13-c110nr Motherboard Replacement: passo 3, imagem 3 %32
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr Motherboard Replacement: passo 4, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement: passo 4, imagem 2 %32 HP Stream 13-c110nr Motherboard Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr Motherboard Replacement: passo 5, imagem 1 %32
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr Motherboard Replacement: passo 6, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement: passo 6, imagem 2 %32 HP Stream 13-c110nr Motherboard Replacement: passo 6, imagem 3 %32
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr Motherboard Replacement: passo 7, imagem 1 %32
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr Motherboard Replacement: passo 8, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement: passo 8, imagem 2 %32
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr Motherboard Replacement: passo 9, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement: passo 9, imagem 2 %32
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr Motherboard Replacement: passo 10, imagem 1 %32
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr Motherboard Replacement, WLAN Module: passo 11, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement, WLAN Module: passo 11, imagem 2 %32
    • Disconnect the WLAN antenna cable from the WLAN module.
  12. HP Stream 13-c110nr Motherboard Replacement: passo 12, imagem 1 %32
    • Remove one (1) Phillips P0 PM2.0x3.0 mm screw.
    • Place one (1) screw on magnetic mat for reassembly.
  13. HP Stream 13-c110nr Motherboard Replacement: passo 13, imagem 1 %32
    • Remove the WLAN Module from device.
  14. HP Stream 13-c110nr Motherboard Replacement, Battery Assembly: passo 14, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement, Battery Assembly: passo 14, imagem 2 %32
    • Use a pick to detach the Battery assembly cable.
  15. HP Stream 13-c110nr Motherboard Replacement: passo 15, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement: passo 15, imagem 2 %32
    • Remove eight (8) Phillips P0 PM2.0x3.0 mm screws from Battery assembly.
    • Place eight (8) screws on magnetic mat for reassembly.
  16. HP Stream 13-c110nr Motherboard Replacement: passo 16, imagem 1 %32
    • Remove Battery Assembly from device.
  17. HP Stream 13-c110nr Motherboard Replacement, USB/Card Reader Board: passo 17, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement, USB/Card Reader Board: passo 17, imagem 2 %32
    • Use a pick to disconnect the USB/Card Reader cable from the System Board.
  18. HP Stream 13-c110nr Motherboard Replacement: passo 18, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement: passo 18, imagem 2 %32
    • Remove three (3) Phillips P0 PM2.0x3.0 mm screws.
    • Place three (3) screws on magnetic mat for reassembly.
  19. HP Stream 13-c110nr Motherboard Replacement: passo 19, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement: passo 19, imagem 2 %32
    • Remove the USB/Card Reader board assembly from the device.
  20. HP Stream 13-c110nr Motherboard Replacement, Heat Sink: passo 20, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement, Heat Sink: passo 20, imagem 2 %32
    • Remove two (2) Phillips P0 PM2.0x2.0 mm screws.
    • Place two (2) screws on magnetic mat for reassembly.
  21. HP Stream 13-c110nr Motherboard Replacement: passo 21, imagem 1 %32
    • Remove the Heat Sink from the System Board.
  22. HP Stream 13-c110nr Motherboard Replacement, Motherboard: passo 22, imagem 1 %32
    • Disconnect the Display Cable.
  23. HP Stream 13-c110nr Motherboard Replacement: passo 23, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement: passo 23, imagem 2 %32
    • Disconnect the Speaker Cable.
  24. HP Stream 13-c110nr Motherboard Replacement: passo 24, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement: passo 24, imagem 2 %32 HP Stream 13-c110nr Motherboard Replacement: passo 24, imagem 3 %32
    • Remove five (5) Phillips P0 PM2.5x3.0 mm screws from System Board assembly.
    • Place five (5) screws on magnetic mat for reassembly.
  25. HP Stream 13-c110nr Motherboard Replacement: passo 25, imagem 1 %32 HP Stream 13-c110nr Motherboard Replacement: passo 25, imagem 2 %32
    • Lift the right side of the System Board and slide it from the device.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 647
