Introdução
The Heat Sink removal guide will assist the user in removal and installation within the HP Stream 13-c110nr.
O que você precisa
Close the device.
Remove AC adapter plug from electrical outlet.
Remove AC adapter from device.
Turn the device off.
Unplug all external devices from device.
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
Place the thirteen (13) screws on magnetic mat for reassembly.
Remove two (2) Phillips P0 PM2.0x2.0 mm screws.
Place two (2) screws on magnetic mat for reassembly.
