Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
HP Stream 13-c110nr Battery Assembly Replacement
O que você precisa
  1. HP Stream 13-c110nr Battery Assembly Replacement, Keyboard Assembly: passo 1, imagem 1 %32
    • Close the device.
    • Remove AC adapter plug from electrical outlet.
    • Remove AC adapter from device.
    • Turn the device off.
    • Unplug all external devices from device.
    • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
  2. HP Stream 13-c110nr Battery Assembly Replacement: passo 2, imagem 1 %32
    • Turn the device upside down with the back facing towards you.
  3. HP Stream 13-c110nr Battery Assembly Replacement: passo 3, imagem 1 %32 HP Stream 13-c110nr Battery Assembly Replacement: passo 3, imagem 2 %32 HP Stream 13-c110nr Battery Assembly Replacement: passo 3, imagem 3 %32
    • Use a pick to remove the two (2) large computer feet along the back edge of the device.
    • Use a pick to remove the two (2) small computer feet.
    • Use a pick to remove the one (1) screw cover.
    • Place rubber computer feet in safe place for reassembly.
  4. HP Stream 13-c110nr Battery Assembly Replacement: passo 4, imagem 1 %32 HP Stream 13-c110nr Battery Assembly Replacement: passo 4, imagem 2 %32 HP Stream 13-c110nr Battery Assembly Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
    • Place the thirteen (13) screws on magnetic mat for reassembly.
  5. HP Stream 13-c110nr Battery Assembly Replacement: passo 5, imagem 1 %32
    • Turn the device over with the front facing towards you.
    • Open the device as shown.
  6. HP Stream 13-c110nr Battery Assembly Replacement: passo 6, imagem 1 %32 HP Stream 13-c110nr Battery Assembly Replacement: passo 6, imagem 2 %32 HP Stream 13-c110nr Battery Assembly Replacement: passo 6, imagem 3 %32
    • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
    • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
  7. HP Stream 13-c110nr Battery Assembly Replacement: passo 7, imagem 1 %32
    • Disconnect the Touchpad cable.
  8. HP Stream 13-c110nr Battery Assembly Replacement: passo 8, imagem 1 %32 HP Stream 13-c110nr Battery Assembly Replacement: passo 8, imagem 2 %32
    • Disconnect the Keyboard Cable.
  9. HP Stream 13-c110nr Battery Assembly Replacement: passo 9, imagem 1 %32 HP Stream 13-c110nr Battery Assembly Replacement: passo 9, imagem 2 %32
    • Disconnect the Power connector cable.
  10. HP Stream 13-c110nr Battery Assembly Replacement: passo 10, imagem 1 %32
    • Remove the Keyboard/Top Cover from the device.
  11. HP Stream 13-c110nr Battery Assembly Replacement, Battery Assembly: passo 11, imagem 1 %32 HP Stream 13-c110nr Battery Assembly Replacement, Battery Assembly: passo 11, imagem 2 %32
    • Use a pick to detach the Battery assembly cable.
  12. HP Stream 13-c110nr Battery Assembly Replacement: passo 12, imagem 1 %32 HP Stream 13-c110nr Battery Assembly Replacement: passo 12, imagem 2 %32
    • Remove eight (8) Phillips P0 PM2.0x3.0 mm screws from Battery assembly.
    • Place eight (8) screws on magnetic mat for reassembly.
  13. HP Stream 13-c110nr Battery Assembly Replacement: passo 13, imagem 1 %32
    • Remove Battery Assembly from device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 808
