Introdução
The Battery Assembly repair guide will assist the user in the removal and installation procedures within the HP Stream 13-c110nr (ENERGY STAR). Over time, laptop batteries naturally degrade, leading to reduced charge capacity and shorter usage times. Replacing the battery can resolve power-related issues and restore your laptop’s portability.
You may need to replace the battery if you experience:
- Rapid battery drain
- The laptop shutting off unexpectedly
- Failure to charge or power on
The battery is a crucial component, and proper handling is essential. If your battery is swollen, take appropriate precautions, as it poses a fire risk. Refer to iFixit’s Swollen Battery Guide for guidance.
Before starting, power down your laptop completely and disconnect it from any power source. Follow this guide step-by-step to safely replace the battery and get your HP Stream 13-c110nr running smoothly again.
O que você precisa
Close the device.
Remove AC adapter plug from electrical outlet.
Remove AC adapter from device.
Turn the device off.
Unplug all external devices from device.
Ferramenta utilizada neste passo:Magnetic Project Mat$19.95
Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
Place the thirteen (13) screws on magnetic mat for reassembly.
Uma outra pessoa concluiu este guia.
