Introdução
This guide will teach you how to replace the USB Ports on the HP Stream 13-c010nr.
  1. Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. Remove the thirteen 5mm Phillips #0 screws from the bottom case. Remove the thirteen 5mm Phillips #0 screws from the bottom case.
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. Flip the laptop over and open it up. Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  6. Use a spudger to flip up the retaining flap on the USB port ribbon cable ZIF socket. Pull the ribbon cable out of the socket.
    • Use a spudger to flip up the retaining flap on the USB port ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  7. Remove the three 3mm Phillips #0 screws from the USB port. Pull out the USB port.
    • Remove the three 3mm Phillips #0 screws from the USB port.
    • Pull out the USB port.
  8. Remove the chip containing the two USB Ports.
    • Remove the chip containing the two USB Ports.
Conclusão
Keegan Lapham
723 reputação
6 Guides authored
Equipe
USF Tampa, Team S1-G3, Cagle Spring 2018 Membro de USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
4 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Todo: 57
