Ir para o conteúdo principal
HP Stream 13-c010nr Charging Port Replacement
O que você precisa
  1. HP Stream 13-c010nr Charging Port Replacement, HP Stream 13-c010nr Disassembly: passo 1, imagem 1 %32
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. HP Stream 13-c010nr Charging Port Replacement: passo 2, imagem 1 %32 HP Stream 13-c010nr Charging Port Replacement: passo 2, imagem 2 %32
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. HP Stream 13-c010nr Charging Port Replacement: passo 3, imagem 1 %32 HP Stream 13-c010nr Charging Port Replacement: passo 3, imagem 2 %32
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. HP Stream 13-c010nr Charging Port Replacement: passo 4, imagem 1 %32
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  5. HP Stream 13-c010nr Charging Port Replacement, Charging Port: passo 5, imagem 1 %32
    • Disconnect the charging port from the motherboard.
  6. HP Stream 13-c010nr Charging Port Replacement: passo 6, imagem 1 %32 HP Stream 13-c010nr Charging Port Replacement: passo 6, imagem 2 %32
    • Remove the two 5mm Phillips screws from the charging port.
    • Remove the bracket.
    • Pull out the charging port.
Conclusão
Keegan Lapham
Membro desde: 02/22/18
759 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S1-G3, Cagle Spring 2018 Membro de USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 495
