Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide includes laptop disassembly to gain access to the internal components and removal of the speakers.
O que você precisa
Flip the laptop over so the bottom is facing up.
Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
You will notice various screws located on the outer edges of the speakers. Using your Philips screwdriver, remove each of these screws.
Connecting the two speakers is a red and black wire located at the edge of the battery. Using your flathead screwdriver, lift the wire upward.
